udfCheckNumUsrStrs()
Check the number of user strings given in the input file.
udfCheckNumUsrStrs( udfHd, nUsrStrs ) ;
AcuSolve User-Defined Function Basic
udfHd
The opaque handle (pointer) which was passed to the user function.
nUsrStrs (integer)
Number of user strings that the function expects.
Return Value
None
This routine verifies that the number of user strings supplied in the input file is the same as the second argument. If it is not, an error message is issued and the solver exits. For example,
udfCheckNumUsrStrs( udfHd, 2 ) ;
This routine expects a valid udfHd.
