udfCheckUgd()
Check the existence of a user global data.
udfCheckUgd( udfHd, ugd ) ;
AcuSolve User-Defined Function Global
udfHd
The opaque handle (pointer) which was passed to the user function.
ugd (string)
Name of the user global data variable.
Return Value
None
This routine verifies that the specified user global data is defined. If it is not, an error message is issued and the solver exits. For example,
udfCheckUgd( udfHd, "nCols" ) ;
None
