udfFirstStep()
Determine whether this is the initial time step of this run.
firstStep = udfFirstStep( udfHd ) ;
AcuSolve User-Defined Function Basic
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- firstStep (integer)
The integer return value firstStep indicates whether or not this is the initial time step of this run:
- 0
- No, this is not the first time.
- 1
- Yes, this is the first time.
Integer firstStep ;
if ( firstStep == 1 ) {
/* possible initialization */
} else {
/* the rest of the time */
This routine expects a valid udfHd.
