udfGetGlobalHistsCurr3()
Get the current global history variables.
vec = udfGetGlobalHistsCurr3( udfHd, nSize, id1, id2, id3 ) ;
AcuSolve User-Defined Function Global
udfHd
The opaque handle (pointer) which was passed to the user function.
nSize (integer)
Size of vector.
id1 (integer)
index 1.
id2 (integer)
index 2.
id3 (integer)
index 3.
Return Value
vec (real)
Pointer to the global vector
This routine returns a pointer to the (id1, id2, id3)-th current global history variables in size nSize vector. For example,
Real* vec ;
This routine expects a valid udfHd.
