udfGetOriData()
Return data from an integrated radiation surface output set.
oriData = udfGetOriData( udfHd, setName, dataName ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- setName (string)
- Name of the RADIATION_SURFACE set.
- dataName (integer)
- Symbolic name of the requested data.
- UDF_ORI_AREA
- Total area.
- UDF_ORI_HEAT_FLUX
- Total radiation heat flux.
- UDF_ORI_TEMPERATURE
- Average temperature.
- UDF_ORI_MEAN_RADIANT_TEMPERATURE
- Mean radiant temperature.
Return Value
- oriData (real)
- Pointer to one-dimensional real array of the requested data. The dimension of the array is 1 for all values of dataName.
Real* oriData ;
Real area, heat_flux ;
oriData = udfGetOriData( udfHd, "car body", UDF_ORI_AREA ) ;
area = oriData[0] ;
oriData = udfGetOriData( udfHd, "car body", UDF_ORI_HEAT_FLUX ) ;
heat_flux = oriData[0] ;
- This routine expects a valid udfHd.
- setName must be a valid name.
- dataName must be one of the values given above.
- The problem must contain the equation system corresponding to the parameter being requested. In particular, the problem must contain a radiation equation in order for the heat flux or temperature quantities to be available.
