udfGetResidualRatio()
Return the current residual ratio of the requested equation.
conv = udfGetResidualRatio( udfHd, eqnName) ;
AcuSolve User-Defined Function Global
udfHd
The opaque handle (pointer) which was passed to the user function.
eqnName (integer)
Symbolic name of the requested equation.
UDF_EQN_PRESSURE
Pressure.
UDF_EQN_VELOCITY
Velocity.
UDF_EQN_SPECIES
Species.
UDF_EQN_EDDY_VISCOSITY
Turbulence eddy viscosity.
UDF_EQN_KINETIC_ENERGY
Turbulence kinetic energy.
UDF_EQN_EDDY_FREQUENCY
Turbulence eddy frequency.
UDF_EQN_MESH_DISPLACEMENT
Mesh displacement.
UDF_EQN_RADIATION
Radiation.
Return Value
conv (real)
This routine returns a pointer containing the current convergence information. If the requested convergence information is not available, an assertion is given.
The dimension of the returned array depends on eqnName as follows:
eqnName Array Dimension
UDF_EQN_PRESSURE 1
UDF_EQN_VELOCITY 1
UDF_EQN_SPECIES udfGetNumSpecs()
UDF_EQN_EDDY_VISCOSITY 1
UDF_EQN_KINETIC_ENERGY 1
UDF_EQN_EDDY_FREQUENCY 1
UDF_EQN_MESH_DISLACEMENT 1
UDF_EQN_RADIATION 1
This routine returns the current residual ratio convergence level. For example,
Real* conv ;
Real  presResRatio;
conv = udfGetResidualRatio( udfHd, UDF_EQN_PRESSURE) ;
presResRatio = conv[0];
This routine expects a valid udfHd and eqnName.
