udfGetUsrHandle()
Return the handle (pointer) to previously saved user data.
usrHandle = udfGetUsrHandle( udfHd, name ) ;
AcuSolve User-Defined Function Basic
udfHd
The opaque handle (pointer) which was passed to the user function.
name (Void*)
Name of the user data.
Return Value
usrHandle (real)
Pointer to user data.
This routine returns the previously saved pointer to the specified user data. If the data is not found, then NULL is returned. For example,
VtkAcuSolve *vtkHd ;
vtkHd = udfGetUsrHandle ( udfHd, "VTK" ) ;
This routine expects a valid udfHd
