udfGetUsrHistsPrev()
Return the array of history variables from the previous time step.
usrHistsPrev = udfGetUsrHistsPrev( udfHd ) ;
AcuSolve User-Defined Function Basic
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
usrHistPrev (real)
The return value is an array of history variables from the previous time step. This array has udfGetNumUsrHists() entries.
This routine returns the array of history variables from the previous time step. For the first time step, this array is initialized to the array given in the input file. The array is read-only. At the end of the time step the "current" history variables are copied into the previous history variables. See udfGetUsrHistsCurr for an example.
This routine expects a valid udfHd.
