udfGetUsrStrs()
Return the array of user supplied strings.
usrStrs = udfGetUsrStrs( udfHd ) ;
AcuSolve User-Defined Function Basic
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
usrStrs (string)
The return value is an array of user strings given in the input file. This array has udfGetNumUsrStrs() entries.
This routine returns the array of user strings given in the input file. For example,
String* usrStrs ;
String inflowOsi ;     /* inflow surface output */
String outflowOsi ;    /* outflow surface output */
udfCheckNumUsrStrs( udfHd, 2 ) ;
inflowOsi = usrStrs[0] ;
outflowOsi = usrStrs[1] ;
This routine expects a valid udfHd.
