udfOpenPipe()
Open a pipe to an external program.
udfOpenPipe( udfHd, command ) ;
AcuSolve User-Defined Function Client
udfHd
The opaque handle (pointer) which was passed to the user function.
command (string)
Name and arguments of the external program.
Return Value
None
This routine opens a client/server pipe to an external program, given by command. The external program must use the standard read/write calls to receive/send ASCII data. For example,
udfOpenPipe( udfHd, "rsh pelican usrPres.pl 4 1 0" ) ;
  • This routine expects a valid udfHd.
  • May only be called from a multiplier function or mesh motion user-defined function.
