udfSetSdEbcId()
Set the ID of a boundary element set.
udfSetSdEbcId( udfHd, ebcId ) ;
AcuSolve User-Defined Subdomain Routine
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- ebcId (integer)
- Boundary element set index.
Return Value
None.
Integer nEbcs, ebcId ;
nEbcs = udfGetNSdEbcs( udfHd ) ;
for ( ebcId = 0 ; ebcId < nEbcs ; ebcId++ ) {
- This routine expects a valid udfHd.
- This routine may only be called within an external code.
- ebcId must be from 0 to nEbcs - 1.
