ufpGetTimeInc()
Get the time increment for the current particle segment.
dt = ufpGetTimeInc ( ufpHd ) ;
AcuTrace User-Defined Function Particle Routine
- ufpHd (pointer)
- The opaque handle which was passed to the user function
Return Value
The return value is the particle time increment (real value). Note that this time increment is not the time increment returned by the AcuSolve User Defined Function udfGetTimeInc.
Real dt;
dt = ufpGetTimeInc( ufpHd ) ;
This routine expects a valid ufpHd as an argument; an invalid argument returns an error.
