| 1. | From the Menu Bar, select Contact Interfaces > Check. |
In the interface list, those with a green interface have a correct definition, the orange ones have to be checked, and the red ones have a bad definition.
| 2. | In the listing window, click the contact interface line to select one interface. |
| 3. | Click to display the interface. |
| 4. | Check the error or warning message in the Message window. |
| 5. | Using the pop-up function (right button on the mouse in the interface list window): |
| • | Click See Incompat. Kinematic Cond. on Secondary to view secondary nodes of tied interfaces with incompatible kinematic conditions. |
| • | Click See Secondary nodes no proj. to view secondary nodes which cannot be projected on the main surface of the tied interface. |
| • | Click See Secondary nodes in Multiple Interfaces to view secondary nodes which are included in several tied interfaces. |
| • | Click See Interfaces. Secondary Nodes in Main Surface to view secondary nodes of tied interfaces which are also defined in the main surfaces of the same or other tied interfaces. |
| • | Click Check penetrations selected interfaces |
| • | Click Time History >> Add or Remove |
| 8. | Click Save to save the modified interface. |
or
Click Save + Sym. to save the interface and automatically create its symmetric: the secondary side becomes the main and the main side becomes the secondary (not available for a Self-Impact interface).
or
Click Cancel to cancel the contact interface modification.
| 9. | Click Close to close the menu. |
Go to
Contact Interface
