| 1. | From the Menu Bar, select LoadCase > Concentrated Load. |
| 2. | The Concentrated Load tab appears with the following menu options. |
Button |
Behavior |
select/unselect all |
review |
create a new object |
pick objects to see in the list. |
pick parts to see in the list and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
select parts in tree to see object in the list. |
cross reference |
show/hide checks |
delete selected item(s). |
| 3. | Right-click to access the context menu, and make a selection from the available choices. |
| 1. | When you select Create New from the context menu, the /CLOAD card panel appears. |
Button |
Behavior |
pick nodes in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
add/remove object by ellipse selection. |
add nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add all nodes. |
pick parts in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add the parts selected in the tree. |
remove the parts selected in the tree. |
| 2. | Click to edit fields and right-click in applicable fields for more options. |
| 3. | Click to expand the sub-menu's and make selections from the menu, as applicable. |
| 4. | Click Save or Cancel when you are finished creating the card. |
| 5. | In the Reference Axis folder: |
| • | Click the Reference Axis folder. |
| • | Define the reference axis using the different tools from the Reference Axis folder. |
| 6. | In the Sensor folder, define the sensor to activate and deactivate the concentrated load. (Learn how to create a sensor.) |
| • | Set a scale factor for the abscissa of the defined curve in the Scale factor field. |
| • | Click Function to modify the function. |
| • | Click Fx and/or Fy and/or Fz to impose the concentrated load (Forces) in translation around the X, Y, or Z direction. |
| • | Click Mxx and/or Myy and/or Mzz to imposed the concentrated load (Moments) in rotation around X, Y, or Z direction. |
| 9. | Click Save to save the created concentrated load; or |
Click Cancel to cancel the concentrated load creation.
| 10. | Click Close to close the menu. |
