| 1. | From the Menu Bar, select LoadCase > Rigid Wall > Modify. |
| 2. | Select rigid walls using one of the following methods: |
Button |
Behavior |
select all the rigid wall(s). |
pick rigid wall(s) in the graphic window. |
draw a box around the rigid wall(s) to select |
pick parts in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
pick rigid wall(s) in the graphic window, drag a box to select parts. |
Click the rigid wall line in the listing window to select it. Several rigid walls from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys. |
displays the rigid walls in the graphic window. |
| 3. | Select only one rigid wall and click |
| • | Change the rigid wall name. |
| • | Modify the rigid wall secondary nodes. |
| • | Modify the rigid wall properties. |
| 4. | Click |
| 5. | Answer the question in the pop-up dialog window with Yes or Cancel. |
| 6. | Click See to view the modified rigid wall. |
| 7. | Click Save to save the modified rigid wall; or |
Click Cancel to cancel the rigid wall modifications.
| 8. | Click Close to close the menu. |
