| 1. | Merge a dummy in the model. (See Merge a dummy for more information.) |
| 2. | Select the desired dummy view. (See Dummy views for more information.) |
| 1. | Click the Ref. points toggle to display the corresponding page. |
| 2. | Set the following information by filling in the fields or by clicking |
| • | Side sill Z coordinate. |
| • | Seat hinge X and Z coordinates. |
| • | B-Pillar X coordinate. |
| • | Front seat bracket X coordinate. |
| • | Floor Z coordinate. |
| 3. | Click the H point toggle to display the corresponding page. |
| 4. | Set the following information by filling in the fields or by clicking |
| • | A: distance Z from the sill. |
| • | B: distance Z from the seat. |
| • | C: distance X from the seat. |
| 5. | Click the Body toggle to display the corresponding page. |
| 6. | Set the following information by filling in the fields or by clicking |
| • | D: distance X between the upper arm joint and the B pillar. |
| • | E: distance X between the head accelerometer and the B pillar. |
| • | F: distance X between the ankle joint and the front seat anchorage point. |
| • | G: distance X between the ankle joints. |
| • | I: distance X between the knee joints. |
| 7. | If necessary, manually adjust the different parts of the dummy. The different operations are defined. |
| 8. | In the Global dummy displacement portion of the window, set the following information by filling in the fields or by clicking |
| • | The Hx field: H point position in X direction. |
| • | The Hy field: H point position in Y direction. |
| • | The Hz field: H point position in Z direction. |
| • | The Rx field: global rotation position around global X axis. |
| • | The Ry field: global rotation position around global Y axis. |
| • | The Rz field: global rotation position around global Z axis. |
