The directory, $MCRASHDIR/messages/CONFIG contains the files with all the messages that will be displayed in the message window and in the dialog toolbar.
Two files are located in this directory:
| • | msg_arrays |
| • | msg_table |
If you need messages in another language, please send an email to: hwsupport@altair.com
Keyword{
Arguments 1
Arguments 2
Arguments n
The comment lines start with:
| • | character /* and finish with */ (can be written on several lines). |
| • | character // and finish with the end of the line. |
KERNEL { 0000 "ERROR: Not possible to open \"%s\"" // comment 0001 "ERROR: End of file \"%s\"" 0002 "Quoted string not found" … 0039 "Not possible to define USER subtype (%i) for a %s" 0040 "%s is not a subtype of %s" 0041 "Not possible to add a %s into an ARRAY of %s type" }
* the text in blue may be modified. |
