| 1. | From the Print menu, you can take a snapshot of the graphic window. |
| 2. | From the menu bar, select Print, and then choose one of the following options: |
| • | png |
| • | jpeg |
The output file name is either hc_out.png or hc_out.jpg, depending on the option you choose.
