| 1. | Select parts in the tree (see Selection List for information on how to select parts in the tree). |
| 2. | From the Menu bar, select Quality > Contour Check. |
HyperCrash displays a thickness range in the left of the graphic window and displays in color the parts with iso-thicknesses. All the parts with a thicknesses out of range are displayed in grey.
| 3. | In the Contour tab, select Thickness from the drop-down menu next to Attributes. |
| 4. | Enter a value in the Min value: field. |
Click
to reset the minimum value of the mode.
| 5. | Enter a value in the Max value: field. |
Click
to reset the maximum value of the mode.
Button |
Behavior |
See / Update display. |
Display only the parts that have a thickness value included in the defined range and select them in the tree. |
Clear the display in the graphic window. |
Increase or decrease the number of colors; or Enter a value in the window Number of colors: and press the ENTER key to validate. |
