| 1. | From the Menu Bar, select Model > Property. |
| 2. | Click |
| 3. | Click the Go to Home Database directory icon ( |
| 1. | Select property and click the See Selected icon ( |
| 2. | Go to the Tree panel, highlight the part. |
| 3. | Click the Isolate Tree Selections icon ( |
| 4. | Go back to the Property panel |
| 5. | Click the Selected parts of tree icon ( |
| 6. | Click Save to allocate the property. |
| 1. | In the Modify panel, select Switch between Model and DB ( |
| 2. | Then click the Change the database directory icon ( |
| 3. | Enter the path to your local database or working directory. |
| 4. | Click the OK button. |
| 5. | Highlight part name. |
| 6. | Click the See selected icon ( |
| 7. | Go to the Tree panel, highlight the part |
| 8. | Click the Isolate Tree Selections icon ( |
| 9. | Go back to the Property panel |
| 10. | Click the Selected parts of tree icon ( |
| 11. | Click Save to allocate the property. |
| 12. | Click Close to close the Property panel. |
| 1. | Go to the Property panel, select property. |
| 2. | Click the See selected icon ( |
Only the parts assigned to the property are displayed in the graphic window.
| 3. | In the Tree panel, highlight the parts. |
| 4. | Click the Isolate Tree Selections button ( |
| 5. | Go back to the Property panel. |
| 6. | Click the Include picked parts button ( |
| 7. | Select the part from the Graphic Window. |
| 8. | After selecting, confirm the selection by clicking Yes in the Dialog Menu Bar. |
| 9. | Click Save to allocate the property. |
| 10. | Click Close to close the Property panel. |
