Use the Rayleigh Damping (
) option from the RADIOSS Tools menu to create, delete, edit, clone or cross reference a Rayleigh Damping card (/DAMP).
In the Rayleigh Damping panel, right-click to access the context menu, and make a selection from the choices of Review, Create New, Delete, Rename, Clone and Cross Reference.
| Note: | Selected Rayleigh dampings may be turned ON or OFF in the display through the Model Browser. |
All Rayleigh dampings can be turned ON or OFF using the Display Graphic objects or Mask all graphic objects icon on the main toolbar.
| 1. | When you select Create New from the context menu, the /DAMP card panel appears. |
Button |
Behavior |
select/unselect all |
review |
create a new object |
pick parts to see in the list and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
select parts in tree to see object in the list. |
cross reference |
show/hide checks |
delete selected item(s). |
| 2. | Click to edit fields and right-click in applicable fields for more options. |
| 3. | Click to expand the Support sub-menu and make selections from this menu as applicable. |
| 4. | Click Save or Cancel when you are finished creating the card. |
