HS-1010: Set Up a Simple Study
Learn how to set up a study on simple functions defined using a Templex template.
- Simple.tpl
- Base input template
The base input template defines two input variables, DV1 and DV2, labeled X and Y, respectively. The objective of this study is to investigate the two random variables X, Y forming the two functions X+Y and 1/X + 1/Y – 2.
Review the Base Input Template
In this step you will use HyperMesh Desktop to review the base input template.
Perform the Study Setup
Perform Nominal Run
Create and Evaluate Output Responses
In this step, you will create two output responses.
