HS-1620: Set Up a Flux Model
Learn how to set up a Flux model in HyperStudy that will investigate the relationship between actuator dimensions and the mechanical force output.
- Copy the model files used in this tutorial from <hst.zip>/HS-1620/ to your working directory.
Setup Flux to work with HyperStudy. For more information, refer to the registrations steps in Flux Model.
Perform the Study Setup
Perform Nominal Run
