ユーザーが作成したクラスを使用してモデリングを簡素化する方法を、並進ジョイント内をスライドするブロックを使って示します。組み込みクラスのシンタックスは、ユーザーが作成したクラスのシンタックスとまったく同じである点に注目してください。
# Model definition #
def sliding_block ():
"""Test case for the LuGre friction model
Slide a block across a surface.
The block is attached to ground with a translational joint that has LuGre friction
model = Model ()
Units (mass="KILOGRAM", length="METER", time="SECOND", force="NEWTON")
Accgrav (jgrav=-9.800)
Integrator (error=1e-5)
Output (reqsave=True)
# Location for Part cm and markers used for the joint markers
qp = Point (10,0,0)
xp = Point (10,1,0)
zp = Point (11,0,0)
ground = Part (ground=True)
ground.jm = Marker (part=ground, qp=qp, zp=zp, xp=xp, label="Joint Marker")
block = Part (mass=1, ip=[1e3,1e3,1e3], label="Block")
block.cm = Marker (part=block, qp=qp, zp=zp, xp=xp, label="Block CM")
# Attach the block to ground
joint = Joint (type="TRANSLATIONAL", i=block.cm, j=ground.jm)
# Apply the LuGre friction to the joint
model.lugre = LuGre (joint=joint)
# Push the block
Sforce (type="TRANSLATION", actiononly=True, i=block.cm, j=ground.jm,
function="3*sin(2*pi*time)", label="Actuation Force")
# Request the DISPLACEMENT, VELOCITY and FORCE of the Joint
model.r1 = Request (type="DISPLACEMENT", i=block.cm, j=ground.jm, rm=ground.jm,
comment="Joint displacement")
model.r2 = Request (type="VELOCITY", i=block.cm, j=ground.jm, rm=ground.jm,
comment="Joint velocity")
model.r3 = Request (type="FORCE", i=block.cm, j=ground.jm, rm= ground.jm,
comment ="Joint force")
return model
## Entry Point ################################################################
if __name__ == "__main__":
model = sliding_block()
model.simulate (type="DYNAMICS", end=4, dtout=.01)
# Change the static friction coefficient and continue simulation
model.lugre.mus=0.5
model.simulate (type="DYNAMICS", end=8, dtout=.01)
