OS-V: 0710 Curved Cantilever Beam
MacNeal-Harder Test This is a curved cantilever beam solved with solid and shell elements. A model is made with each element's type to investigate the effect of distorted elements with a high aspect ratio.
図 1. FE Model of the Beam with Boundary Conditions and Loadcases
Benchmark Model
Six types of elements are used for this problem. They are tria-shell, quad-shell, and hexa-solid elements, each with 1st and 2nd order. Two loading cases are used for each model; in-plane bending, transverse bending. For both load cases, unit loads are applied in a consistent fashion over all of the nodes at the tip of the beam.
Load Type | Component | Value |
In-plane bending | UY | 0.08734 |
Transverse bending | UZ | 0.5022 |
Linear Static Analysis Results
In-plane Bending | Transverse Bending | |
QUAD4 | 0.952 | 0.955 |
QUAD8 | 1.015 | 0.984 |
TRI3 | 0.025 | 0.950 |
TRI6 | 1.005 | 0.961 |
HEX8 | 0.880 | 0.820 |
HEX20 | 1.009 | 0.946 |
Model Files
必要なモデルファイルのダウンロードについては、モデルファイルへのアクセスを参照してください。
- CBhex8.fem
- CBhex20.fem
- CBquad4.fem
- CBquad8.fem
- CBtri3.fem
- CBtri6.fem
Reference
MacNeal, R.H., and Harder, R.L., A Proposed Standard Set of Problems to Test Finite Element Accuracy, Finite Elements in Analysis and Design, 1 (1985) 3-20.
