OS-V: 0520 Sandwich Shell
Test No: R0031/3 OptiStruct examines the z deflection at C, Normal XX stress at C, Normal YY stress at C and Shear stress at E for linear static analysis.
図 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
Quad4 elements are used to create Ply laminates and with SMCORE for the simply supported one quarter model. A uniform normal pressure of 200psi is applied on the plate.
- Face Sheets
- Ex
- 10.0 × 106 psi
- xy
- 0.3
- Ey
- 4.0 × 106 psi
- Gxy
- 1.875 × 106 psi
- Core
- Ex
- 0.0
- Gxz
- 3.0 × 104 psi
- Gyz
- 1.2 × 104 psi
Linear Static Analysis Results
Target | OptiStruct Results | Normalized with the Target Value | |
Laminated Plate (PCOMPP): | |||
Z deflection at C (inches) | -0.123 | -0.123 | 1 |
xx at C | 34449 | 34126.09 | 1.00946226 |
yy at C | 13390 | 13375.11 | 0.99812263 |
Τxy at E | -5067.5 | -5080.6 | 0.99742156 |
SMCORE (PCOMPG): | |||
Z deflection at C (inches) | -0.123 | -0.078 | 1.57692308 |
xx at C | 34449 | 32578.56 | 1.05741322 |
yy at C | 13390 | 14508.05 | 0.9201788 |
Τxy at E | -5067.5 | -5327.68 | 0.95116448 |
Model Files
必要なモデルファイルのダウンロードについては、モデルファイルへのアクセスを参照してください。
- compssq4.fem
- compssq4smcore.fem
Reference
NAFEMS R0031 - Composite Benchmarks, Hardy 2001
