OS-V: 0395 Simply-Supported Thick Square Plate Random Forced Vibration Response
Test 21R OptiStruct is used to investigate the Peak Displacement in z-direction and extreme fiber bending stress at undamped Natural Frequency (at the center of the plate).
図 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
The 2nd order and 1st order quad elements are used to model the square plate of thickness 1.0m. The z-rotation and x, y translations are fixed for all the nodes, z-translation is fixed along all four edges, x-rotation is fixed along the edge x=0 and x=10 and y-rotation is fixed along the edge y=0 and y=10. A steady-state random forcing with uniform power spectral density (of force) PSD= (106 N/m2)2/Hz is induced in the z-direction. For modal analysis solution, a damping ratio of 0.02 is applied in all 16 modes and for direct solution, Rayleigh damping factor α1=5.772 and α2=6.929×10-5 are given.
- Property
- Value
- Young’s Modulus
- 200 × 109 N/m2
- Poisson’s Ratio
- 0.3
- Density
- 8000 kg/m3
Frequency Response Summary
f*
- Closed form solution
Peak Displacement PSD (mm2/Hz) | Peak Stress PSD ((N/mm2)2 | Frequency (Hz) | |
Reference Solution | 3401.81 | 641200.00 | 45.90 |
HOE: | |||
Direct Solution | 3929.62 | 892303.43 | 45.24 |
Normalized | 0.865684214 | 0.718589639 | 1.014588859 |
Modal Solution | 3928.88 | 892421.36 | 45.27 |
Normalized | 0.865847264 | 0.718494681 | 1.013916501 |
LOE: | |||
Direct Solution | 3607.25 | 600979.1 | 45.62 |
Normalized | 0.943048028 | 1.066925622 | 1.006137659 |
Modal Solution | 3606.23 | 600094.2 | 45.63 |
Normalized | 0.943314764 | 1.068498912 | 1.00591716 |
Model Files
必要なモデルファイルのダウンロードについては、モデルファイルへのアクセスを参照してください。
- Test21RHOED.fem
- Test21RHOEM.fem
- Test21RLOED.fem
- Test21RLOEM.fem
Reference
NAFEMS R0016 - Selected Benchmarks for Forced Vibration, J Maguire, D J, Dawswell, L Gould 1989
