OS-V: 0410 Cantilever with Off-Center Point Masses
Test No. FV4 The problem is set up to test the behavior of coupling between torsional and flexural, off-center inertial axis, and close eigenvalues. OptiStruct is used in this normal modes analysis.
図 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
The 2-node simple beam elements are used to model the problem. The cantilever beam consists of five elements. Two rigid elements are used to connect mass 1, 10000 kg, and mass 2, 1000 kg, at the end of the cantilever beam. All degrees of freedom at end A are constrained.
- Property
- Value
- E
- 200 x 109 N/m2
- 8000 kg/m3
Modal Analysis Results
f*
- Closed form solution
Mode 1 | Mode 2 | Mode 3 | |||
f* CBAR |
1.723 Hz 1.0054 |
f* CBAR |
1.727 Hz 1.0048 |
f* CBAR |
7.413 Hz 1.008 |
Mode 4 | Mode 5 | Mode 6 | |||
f* CBAR |
9.972 Hz 1.0055 |
f* CBAR |
18.155 Hz 1.0067 |
f* CBAR |
26.957 Hz 1.0068 |
Model Files
必要なモデルファイルのダウンロードについては、モデルファイルへのアクセスを参照してください。
The model file used in this problem includes:
fv4.fem
Reference
NAFEMS R0015 - Selected benchmarks for natural frequency analysis
