Cylinder
Model ElementThe Cylinder element allows you to represent a geometric figure with straight parallel sides and a circular cross section.
Class Name
Cylinder
Attribute Summary
Name Property Modifiable by command? Designable?
end_caps Enum (“OPEN CLOSE TOP_ONLY BOTTOM_ONLY”) No
cm Reference(Marker) Yes
radius Double () Yes
length Double() Yes
seg Int ()
material_inside Bool ()
color String()
hidden Bool() No
Usage
Cylinder (cm=Marker(), radius=120, length=200)
Attributes
end_caps
Enum ()
This property allows you to control the appearance of the cylinder. Four options are available:
  • OPEN
  • CLOSED
  • TOP_ONLY
  • BOTTOM_ONLY
cm
Reference (Marker)
The marker is used as a coordinate system for the cylinder graphic. It represents the center of the circular section at the base of the cylinder.
radius
Double()
The radius of the cylinder graphic.
length
Double()
The length of the cylinder graphic.
seg
Int ()
Specifies the number of segments used to represents the Cylinder.
material_inside
Bool ()
Specifies if the graphic has material inside or outside. material_inside is a Boolean flag (True/False).
True means the geometry is solid. In other words, it is filled with material and its exterior is devoid of material. Consequently, the surface normals of the geometry point outward.
False means the converse: The exterior of the geometry is filled with material and the interior is devoid of material. In this case, the surface normals of the geometry point inward.
color
String()
The color of the graphic for H3D animation. Specified as RGB (Red : Green : Blue).
hidden
Boolean
Specifies weather the graphics is being written to the H3D file or not.
  • True implies that the graphic is hidden and is not written to the H3D file.
  • False implies that the graphic is not hidden and is written to the H3D file.
This attribute is optional. When not specified, it defaults to False.
Examples
Define cylinder geometry.
  1. See Properties for an explanation about what properties are, why they are used, and how you can extend these.
