Model ElementThe
H3dOutput element allows you specify various options for generating
an H3dOutput file.
Attribute Summary
Name |
Property |
Modifiable by
command? |
Designable? |
save |
Bool
No |
No |
linear_anim |
Bool
increment |
Int
start |
Double () |
end |
Double () |
format |
Enum
("AUTO MODAL NODAL NODALG", default="AUTO") |
stress_format |
Enum
("NONE TENSOR", default="NONE") |
strain_format |
Enum
Usage
H3dOutput (optional parameters)
Attributes
- save
- Bool
- "True" creates the H3D file.
- "False" turns off generation of the H3D file.
- This attribute is optional. Initially it is set to
"True".
- increment
- Integer
- Controls how often data is written to the H3D file. For example,
"2" means data is written at every second step.
- This attribute is optional. When not specified, and
type="ON", output is written every
step.
- start
- Double
- Specifies the start time for writing the H3D file.
type="ON", start
defaults to 0.0.
- end
- Double
- Specifies the end time for writing the H3D file.
type="ON", end
defaults to the simulation end time.
- format
- String
- Select one from "MODAL", "NODAL",
"NODALG", and "AUTO"
- "MODAL": For flexible bodies, the mode shape data
and time history of the modal participation factors will be stored
in the H3D file. This approach incurs a computational cost at load
time as nodal results must be computed from modal results. Also,
this H3D file cannot be viewed with HyperView Player.
- "NODAL": For flexible bodies, node data are stored
for each time frame. This usually produces larger H3D files than the
MODAL option. However visualization is much
faster since the modal to nodal conversion is not required during
post-processing. Furthermore, "nodal" H3D files can
be viewed using HyperView Player.
- "NODALG": The global displacement of the nodes are
written in one dataset to the H3D file. This is done by combining
the rigid body transformation + local deformation and to obtain the
global displacement of the node. It is primarily used for
animation.
- "AUTO": This method will select the method that
yields the smallest H3D file.
- Default = "AUTO".
- stress or stress_format
- String
- Select one option from "NONE" and "TENSOR"
(Default = TENSOR).
- stress = "NONE": The stress
results are not output to the H3D file. This option will help reduce
the H3D file size for large model. It should always be used if
stress results are of no interest.
- stress_format = "TENSOR": The
stress results are written in tensor format to the H3D file.
HyperView will calculate the von
Mises and other parameters from the stress tensor.
- This attribute is optional. When not specified, it defaults to
"NONE".
- strain or strain_format
- String
(Default = TENSOR).
- strain = "NONE": The strain
strain results are of no interest.
- strain_format = "TENSOR": The
strain results are written in tensor format to the H3D file.
"NONE".
The example below demonstrates how
H3dOutput options may be
defined.
h3d = H3dOutput (save=True, inc=1, start=0.2, end=1.3, format="AUTO", stress="TENSOR", strain="TENSOR")
- See Properties for an
explanation about what properties are, why they are used, and how you can extend
these.
