loc_between
MDL FunctionComputes a new point that resides between the given points.
The distance between the new point and the first point satisfies the following relationship: (p_new – p_1)/(p_2-p_1) = ratio
Signature
point = loc_between(first_point, end_point, dist_ratio)
Input Arguments
first_point
Point that defines the start of the line.
end_point
Point that defines the end of the line.
dist_ratio
Distance ratio used to compute the new point.
Return Value
point
The point that satisfies the requirement.
Usage
# Compute the point whose cooridnates is (0,3,0)
     first_point = Point(0,0,0),
     end_point = Point(0,10,0),
     dist_ratio = 0.3,
