MotionSolve
MotionSolve
2022
  1. Home
  2. MotionSolve User Guide
    MotionSolve is a system level, multi-body solver that is based on the principles of mechanics.
  3. MotionSolve Optimization Guide
  4. Application Areas
    Optimization is a vast area that has a many applications in diverse areas such as engineering, economics, business and medicine.
  • What's New
  • Overview
  • Tutorials
  • MotionSolve User Guide
  • MotionSolve Reference Guide
Index
MotionSolve
2022
MotionSolve
  • What's New
    View new features for MotionSolve 2022.
  • Overview
    MotionSolve® is an integrated solution to analyze, evaluate, and optimize the performance of multi-body systems.
  • Tutorials
    Discover MotionSolve functionality with interactive tutorials.
    • Introduction to MotionSolve
    • Platform Support, Recommended Hardware, and Licensing
    • Run MotionSolve
    • Model Systems
    • Model Simulations
    • Visualize Results - Animation and Request Plots
    • Couple MotionSolve with Other Software
    • Customization Capabilities
    • Analysis Tips
    • User Subroutines in MotionSolve
    • MSolve API
    • MotionSolve Verification Manual
    • NLFE Validation Manual
    • MotionSolve Optimization Guide
      • Introduction
        The MotionSolve Optimization Guide explains the design sensitivity and optimization capabilities in MotionSolve.
      • Optimization Capabilities in MotionSolve
        Optimization capabilities in MotionSolve include equations of motion for a multibody system, design variables and limits, and analysis support.
      • Application Areas
        • Application Area 1: Path Synthesis
        • Application Area 2: System Assembly
        • Application Area 3: Defining Hard Points (or design points) in a Suspension
        • Application Area 4: Parameter Identification
        • Application Area 5: Multi-objective Optimization
        • Application Area 6: Optimize Dynamic Response
        • Application Area 7: Minimize Energy Consumption
        • Application Area 8: Cam Hinge Optimization
        • Application Area 9: Appliance Design
      • Optimization Input Data
        The input data for an optimization is organized in a python parametric model class with methods that operate on the class.
      • Optimization Output Data
        Every optimization run generates a variety of files.
      • Advanced Topics
        Advanced topics include a scaling optimization problem and tips on how to debug optimization runs.
      • SLA Suspension Example
        This example, referred to as MV3010 in this section, describes the optimization of an SLA suspension and is also available in MotionSolve tutorial topics/solvers/ms/optimization_using_mv_hs_intro_r.html#optimization_using_mv_hs_intro_r.
      • PID Controller Example
        In this example, we are designing a PID controller whose job is to minimize the effects of a disturbance force on the position, velocity, and acceleration of a block.
      • Glossary
    • Track Model
      A continuous track plug-in for tracked vehicles, such as bulldozers, excavators, robots, snowmobiles, and military vehicles.
    • MotionSolve Environment Variables
    • References
    This manual provides a detailed list and usage information regarding command statements, model statements, functions and the Subroutine Interface available in MotionSolve.
View All Altair Simulation Help
MotionSolve
MotionSolve
2022
  1. Home
  • What's New
  • Overview
  • Tutorials
Index
Application Areas
This section focuses on problems that have been solved with MotionSolve.
