PlantState
Command ElementPlantState is a container for Solver Variables that is used to generate a linear representation of a model about an operating point.
Class Name
PlantState
The linear representation is used for both eigenvalue analysis and state matrix generation. Use PlantState to define a set of states used in linearization. Often the choice of state variables is determined by the solver. With PlantState (or Pstate), you can define a preferred set of states corresponding to what is usually experimentally measured.
Attribute Summary
Name Property Modifiable by command? Designable?
id Int() Yes No
label Str()
variables Reference (Variable, count=0)
Usage
#1: define a PlantState instance referencing solver variable
PlantState(variables=[var2])
Attributes
variables
Specifies a list of variables used as states in eigen analysis and state space matrix representation. MotionSolve attempts to select the specified variables whenever possible.
See Also
Reference: PlantState
