Q
The Q()function returns the modal displacement for the requested mode (m_id) for the flexible body specified (f_id). This function can be used in your model as a valid MotionSolve expression.
Q(f_id, m_id)
Arguments
f_id
The ID of the flexible body in the model.
m_id
The mode ID whose displacement is requested.
Note: m_id > 6, that is, the expression is only supported for non-rigid body modes.
<Post_Request
     id                  = "2"
     type                = "EXPRESSION"
     label               = "Modal displacement"
     expr2               = "Q(30102,7)"
     expr3               = "Q(30102,8)"
     expr4               = "Q(30102,9)"
     expr6               = "Q(30102,10)"
     expr7               = "Q(30102,11)"
     expr8               = "Q(30102,12)"
