SET_DAE_ERROR
Utility/Data Access SubroutineThe SET_DAE_ERROR utility subroutine sets the integration error tolerance for the DAE integrator DSTIFF.
Fortran Calling Syntax
CALL SET_DAE_ERROR(ERROR)
C/C++ Calling Syntax
c_set_dae_error(error)
Python Calling Syntax
py_set_dae_error(error)
MATLAB Calling Syntax
m_set_dae_error(error)
Attributes
ERROR
Double precision
Specifies the error tolerance to be set for the DSTIFF integrator. ERROR must be greater than zero.
Complete Definition
The SET_DAE_ERROR is a function style subroutine which can be used in a TUNSUB subroutine to set the integration error tolerance for the DAE integrator DSTIFF and for FIM_D. Using this function, the integration error tolerance can be modified spontaneously as per the simulation needs.
This function is typically used to improve accuracy or performance of the multibody simulation.
Please see TUNSUB for a GETNUMID usage example for SET_DAE_ERROR.
