SPLINE_READ
ModelingUsed to read x, y, and optionally z, data from a file for use with a Reference_Spline element.
Use
User-defined request calling a SPLINE_READ to obtain the x, y, and optionally z, vector to define a Reference_Spline element.
<Reference_Spline
     id              = "301001"
     usrsub_dll_name = "c:\work\test.dll"
     file_name       = "c:\data\spring1.dat"
     block_name      = "spring_force">
</ Reference_Spline>
Fortran Calling Syntax
SUBROUTINE SPLINE_READ (ID, FILE_NAME, BLOCK_NAME, ERRFLG)
C/C++ Calling Syntax
void STDCALL SPLINE_READ (int *id, char *file_name, int file_name_len, char *block_name, int block_name_len, int *errflg)
Python Calling Syntax
def SPLINE_READ(id, file_name, block_name):
    return errflag
MATLAB Calling Syntax
function errflg = SPLINE_READ(id, file_name, block_name)
Attributes
ID
[integer]
The user-defined Reference_Spline element identifier.
FILE_NAME
[CHARACTER*(*)]
An array of dimension 132 containing the FILE_NAME argument value.
BLOCK_NAME
[CHARACTER*(*)]
An array of dimension 132 containing the BLOCK_NAME argument value.
Output
ERRFLG
[logical]
The variable to indicate the status of SPLINE_READ reading the data. Using PUT_SPLINE, set it to TRUE if there are errors, and FALSE if there are no errors. A return value of TRUE causes MotionSolve to stop relevant computations.
  1. The following example demonstrates the SPLINE_READ user subroutine using the Python scripting language:
      x =6*[0.0]
      y =6*[0.0]
      x[0] =0.0
      x[1] =0.3
      x[2] =0.5
      x[3] =1.0
      x[4] =1.5
      x[5] =2.0
      y[0] =0.0
      y[1] =0.0
      y[2] =0.0
      y[3] = -0.05
      y[4] = -0.15
      y[5] = -0.3
      z =0.0
      errflg = py_put_spline(id, x, y, z)
      return errflg
  2. In the example below, the SPLINE_READ subroutine is used to populate a Reference_Spline model element with values that are read from an external file data.txt.
    1. The model element:
      <Reference_Spline
           id                  = "301001"
           label               = "Excite"
           interpreter         = "Python"
           script_name         = "read_curve.py"
           usrsub_fnc_name     = "SPLINE_READ"
           file_name           = "data.txt"
           block_name          = "dummy"
           linear_extrap       = "TRUE"
    2. The external file data.txt contains a comma separated list of x, y values as shown below:
        0,     0
        0.1,   4.045084972
        0.2,   4.755282581
        0.3,   1.545084972
        0.4,   -2.938926261
        0.5,   -5
        0.6,   -2.938926261
        0.7,   1.545084972
        0.8,   4.755282581
        0.9,   4.045084972
        1,     1.07195E-14
        1.1,   -4.045084972
        1.2,   -4.755282581
        1.3,   -1.545084972
        1.4,   2.938926261
    3. The user subroutine SPLINE_READ is written in the Python scripting language and is shown below:
      # This is an example for a spline read
      def SPLINE_READ(id, file_name,block_name):
          x_ = []
          y_ = []
      # Open the external file for reading
          f = open(file_name, 'r')
      # Loop throught the file contents to get x,y values
        while 1:
         line = f.readline()
         if not line:
            break
         cols = line.split(',')
         x_.append(float(cols[0]))
         temp = cols[1].split('\n')
         y_.append(float(temp[0]))
         z_ = 0.0
      # Use py_put_spline to put the x, y, z values into reference_spline
        errflg = py_put_spline(id, x_, y_, z_)
        return errflg
