UserGraphic
Model ElementThe UserGraphic element allows you to generate your own user defined geometry.
Class Name
UserGraphic
This element can only be created by writing or using an associated user written subroutine. The associated user function calculates node positions for a user-defined graphics element.
Attribute Summary
Name Property Modifiable by command? Designable?
rm Reference(Marker) No No
nodes Double(count=0)
faces Int(count=0)
refinement_level Int()
color String()
hidden Bool()
Usage
# Defined in a compiled user subroutineUserGraphic (function=userString, routine=string)# Defined in a Python functionUserGraphic (function=userString, routine=functionPointer)
Attributes
User-subroutine defined in a compiled DLL
rm
Reference(Marker)
The reference frame of the output mesh.
increment
Int()
A number that indicates the calling frequency of the corresponding GRASUB. The default is 4. The number controls the temporal resolution of the mesh. A finer resolution will results in a larger CPU time to generate and process the mesh and vice versa.
function
String defining a valid user function MotionSolve expression.
The list of parameters that are passed from the data file to the user defined subroutine where the UserGraphic is defined.
The function attribute is mandatory.
routine
String.
Specifies an alternative name for the user subroutine. The name consists of two pieces of information, separated by "∷". The first is the path name to the shared library containing the function that computes the response of the user-defined Variable. The second is the name of the function in the shared library that does the computation.
An example is: routine="/staff/Altair/engine.dllmyGrasub"
  • "/staff/Altair/engine.dll is the DLL
  • "mGrasub" is the function within this DLL that generates the graphic object
The attribute routine is optional.
When not specified, routine defaults to "GRASUB".
User-subroutine defined in a user-written Python script
function
The list of parameters that are passed from the data file to the user defined subroutine.
routine
Pointer to a callable function in Python.
An example is: routine=myGrasub
  • myGrasub is a Python function or method that can be called from wherever the model resides.
When not specified, routine defaults to GRASUB.
hidden
Boolean
Specifies weather the graphics is being written to the H3D file or not.
  • True implies that the graphic is hidden and is not written to the H3D file.
  • False implies that the graphic is not hidden and is written to the H3D file.
This attribute is optional. When not specified, it defaults to False.
Optional Attributes – Available to all description methods
color
String()
The color of the graphic for H3D animation. Specified as RGB (Red : Green : Blue).
Define a UserGraphic to generate a mesh geometry representing a cam profile:
UserGraphic (function="USER()",routine=cam_grasub)
  1. See Properties for an explanation about what properties are, why they are used, and how you can extend these.
