Load Model
Command ElementThe Load_Model command reads a MotionSolve XML file and builds a new multibody model.
This command may be used in conjunction with the Save command, which is used to save a multibody model as a MotionSolve XML file, following a simulation. Such a file contains all the model information necessary to restart the simulation.
<Load_Model
     model_file       = "valid_file_name.xml"
     result_file      = "valid_file_name.mrf"
     anima_file       = "valid_file_name.h3d"
Attributes
model_file
The name of the MotionSolve XML file to be loaded.
result_file
The name of the MRF file that will store the results of the new simulation.
anima_file
The name of the H3D file that will store the results of the new simulation.
The following example demonstrates using the Load_Model command to load a MotionSolve XML file and then performing a transient simulation until 5 seconds.
<Command>
   <Load_Model
      model_file        = "save1.xml"
      result_file       = "output.mrf"
      anima_file        = "output.h3d"
   <Simulate
      analysis_type     = "Transient"
      end_time          = "5."
      print_interval    = "0.01"
</Command>
The file save1.xml was created using the Save command, following a transient simulation for three seconds.
  1. A new MRF file is generated for each new simulation.
  2. A single H3D file is produced which contains the animation results for the entire simulation.
