Constraint: PTdSF
Model ElementThe Constraint_PTdSF element constrains a fixed point on a body to slide along a surface that passes through the origins of a specified set of markers.
These markers may belong to different bodies. As the markers move in space, the surface is calculated at every time step using CUBIC spline interpolation through the marker origins. Hence, the surface deforms as the markers move about.
<Constraint_PTdSF
id = "integer"
[ label = "string" ]
i_marker_id = "integer"
ref_dsurface_id = "integer"
/>Attributes
- id
- Element identification number, (integer>0). This number is unique among all Constraint_PTdSF elements.
- label
- The name of the Constraint_PTdSF element.
- i_marker_id
- Specifies a Reference_Marker whose origin defines the point that is constrained to move along the deformable curve.
- ref_dsurface_id
- Specifies the deformable surface used to define the Constraint_PTdSF element.
<Reference_DeformSurface
id = "1"
end_type = "NATURAL"
num_marker_row = "7"
num_marker_col = "7">
30101490 30101500 30101510 30101520 30101530 30101540 30101540
30101420 30109781 30113791 30117801 30121811 30125821 30101480
30101350 30108711 30112721 30116731 30120741 30124751 30101410
30101120 30102061 30103071 30104081 30105091 30106101 30101130
30101140 30110571 30114581 30118591 30122601 30126611 30101200
30101210 30111641 30115651 30119661 30123671 30127681 30101270
30101280 30101290 30101300 30101310 30101320 30101330 30101340
</Reference_DeformSurface>
<Constraint_PTdSF
id = "1"
i_marker_id = "30107780"
ref_dsurface_id = "1"
<Post_Graphic
id = "500000"
type = "DeformSurface"
surface_id = "1"
nseg_u = "30"
nseg_v = "30"
- The Reference_DeformSurface element does not possess any inherent inertia, stiffness or damping properties. Additional modeling elements are necessary to capture these effects. See the Example.
- The markers used to define the Reference_DeformSurface may belong to different bodies which may be of type Body_Point, Body_Rigid, or Body_Flexible.
- The Constraint_PTdSF element can be thought of as a generalization of the Constraint_PTSF element. In fact, when all the markers belong to a single rigid body, Constraint_PTdSF reduces to Constraint_PTSF.
- To correctly model a
Constraint_PTdSF element, you must ensure that the point which
is referenced by the i_marker_id will always fall in range of the
deformable surface throughout the simulation. MotionSolve
calculates a (u, v) value for the point's current position with respect to the
deformable surface. This (u, v) value must always stay within range of the defined
u_span and v_span, for example.
-u_span/2 ≤ u ≤ + u_span/2
-v_span/2 ≤ v ≤ + v_span/2
If the current u or v value goes out of this range, MotionSolve will hold the u or v value at the boundary until the point falls back in range of the deformable surface. However, this may lead to incorrect results. You are encouraged to check the results for correctness in such a situation. For more information, please refer to the Reference_DeformSurface model element.
