AELIST
Bulk Data Entry Defines a list of aerodynamic box IDs.
AELIST SID E1 E2 E3 E4 E5 E6 E7
E8 etc.
AELIST 14 200 THRU 610 621 THRU 730 900
901
SID Aerodynamic list set identification number.
(Integer > 0)
Ei List of aerodynamic box IDs.
(Integer > 0 or THRU)
  1. The AELIST entry can be referenced by AESURF and SPLINEi entries. Refer to these entries for the meaning of the data provided.
  2. When the THRU option is used, all intermediate boxes should exist. The word THRU may not appear in field 3 or 9 (2 or 9 for continuation lines).
  3. Embedded Blank fields are not allowed.
