AESURF
Bulk Data Entry Specifies an aerodynamic control surface as a member of the set of aerodynamic extra points. The forces associated with this controller will be derived from rigid rotation of the aerodynamic model about the hinge line(s).
AESURF ID LABEL CID1 ALID1 CID2 ALID2 EFF
CREFC CREFS
AESURF 88 ELEV 2 34 3 35
15.0 200.0
ID Controller identification number.
(Integer > 0)
LABEL Controller name.
(Character String)
CIDi Rectangular coordinate system with a Y-axis identification number that defines the hinge line of the control surface component.
(Integer > 0)
ALIDi Identification of an AELIST Bulk Data Entry which identifies all aerodynamic elements which make up the control surface component.
(Integer > 0)
EFF Control surface effectiveness. 4
Default = 1.0 (Real ≠0.0)
CREFC Reference chord length for the control surface.
Default = 1.0 (Real > 0.0)
CREFS Reference surface area for the control surface.
  1. The ID on AESURF and AESTAT entries are ignored.
  2. The degrees-of-freedom defined on this entry represent a rigid body rotation of the control surface components about their hinge lines.
  3. Either one or two control surface components may be defined.
  4. If EFF is specified, then the forces produced by this surface are modified by EFF (as in, to achieve a 40% reduction, specify EFF=0.60).
  5. The continuation line is not mandatory.
  6. The CREFC and CREFS values are only used in computing the non-dimensional hinge moment coefficients.
