Even though the deformation patterns are similar for both linear and nonlinear analyses, the
stress patterns differ. Though the horizontal loads are in opposing directions in the lug,
the stress distribution in the web for the linear run are the same around both the lug holes
which is not correct. This happens as all the gaps are in a closed condition for the linear
analysis. Nonlinear gap analysis gives more accurate representation. The gap status, open or
closed, depending on loading condition can also be observed from the
.out
file:
ITERATION 0
NONLINEAR ITERATION SUMMARY Subcase 1
LOAD FACTOR: 0.1000
Nonlinear Error Measures Gap Elem Status
ITER EUI EPI EWI Open Closed
1 9.9000E+01 1.1659E+00 1.1659E+00 23 25
2 2.9097E-02 2.5218E+02 1.1274E+01 23 25
3 8.4208E-05 1.9063E+01 1.9427E-02 22 26
4 1.4632E-06 0.0000E+00 0.0000E+00 22 26
