.bdst file
The .bdst file is an OptiStruct ASCII format results file.
File Creation
This file is created in a static analysis run when the BORE Bulk Data Entry(s) are present in the model. The .bdst file contains Bore Deformation results at various Bore Depths (Z-Depth). These results are defined at all the Orders up to the order defined on the ORDER field on the BORE Bulk Data Entry.
File Contents
Result Description
Bore Deformation Bore Deformation output from Static Analysis.
Output is controlled by the BORE Bulk Data Entry.
File Format
The .bdst file has the following format:
For each Bore (BORE entry), the following header is used:
  Z-depth order# i
Where,
Z-depth
Bore depth at the Layer under consideration.
Order# i
The Fourier Series Order up to the ORDER defined on the BORE entry.
  1. This file is only output when the BORE entry is present in the input deck.
