BNDFIX
Bulk Data Entry Defines the degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
BNDFIX GID1 IC1 GID2 IC2 GID3 IC3
BNDFIX 1220 12345
GIDi Grid of scalar point identification numbers.
No default (Integer > 0)
ICi Component numbers.
  1. BNDFIX and BSET are equivalent.
  2. ASET, BNDFIX and BNDFREE; all three are not allowed in the same deck.
  3. If BNDFREE and ASET are present, the DOFs associated with ASET would be in BNDFIX; except the DOF assigned to BNDFREE.
  4. If BNDFIX and ASET are present, the DOFs associated with ASET would be in BNDFREE; except the DOF assigned to BNDFIX.
