BNDFREE
Bulk Data Entry Defines the degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
BNDFREE GID1 IC1 GID2 IC2 GID3 IC3
BNDFREE 1220 12345
GIDi Grid of scalar point identification numbers.
No default (Integer > 0)
ICi Component numbers.
  1. BNDFREE and CSET are equivalent.
  2. ASET, BNDFIX and BNDFREE are not allowed in the same deck.
  3. If BNDFREE and ASET are present, the DOFs associated with ASET would be in BNDFIX; except the DOF assigned to BNDFREE.
  4. If BNDFIX and ASET are present, the DOFs associated with ASET would be in BNDFREE; except the DOF assigned to BNDFIX.
