CMBUSHE
Bulk Data Entry Defines a bushing element without reference to a property entry.
CMBUSHE EID   G1 G2 X1, G3 Y1 Z1
    "K" K1EID K2EID K3EID K4EID K5EID K6EID
    "B" B1EID B2EID B3EID B4EID B5EID B6EID
    "P" P1 P2 P3 P4 P5 P6
CMBUSHE 4   1 2 1.0 0.0 0.0
    K 100 100 100 1 1 1
    B 1 1 1 1 1 1
    P 0 0 0 0 0 0
EID Unique element identification number.
(Integer > 0)
G1 Grid point identification number.
(Integer > 0)
G2 Grid point identification number.
(Integer > 0)
G3 Grid point identification number to optionally supply X1, Y1, and Z1 in conjunction with G1.
(Integer > 0)
X1, Y1, Z1 Orientation vector of the bushing.
(Real)
K Stiffness specifier.
K1EID, K2EID, K3EID Translational stiffness MBVAR ID.
Default = 0 (Integer ≥ 0 or blank)
K4EID, K5EID, K6EID Rotational stiffness MBVAR ID.
B Damping specifier.
B1EID, B2EID, B3EID Translational damping MBVAR ID.
B4EID, B5EID, B6EID Rotational damping MBVAR ID.
P Preload specifier.
P1, P2, P3 Translational preload.
P4, P5, P6 Rotational preload.
  1. This card is represented as a spring element in HyperMesh.
