CMSMETH
Subcase Information Entry The CMSMETH command can be used to request that only a component mode synthesis solution be performed and to select a component mode synthesis method definition to be used.
CMSMETH = option
Argument Options Description
option <CMSID>
No default
CMSID
Identification of a CMSMETH Bulk Data Entry.
  1. All subcases must have the same MPC reference; in which case it runs the component mode synthesis (flexible-body preparation) solution sequence using the CMSMETH reference and the common MPC reference.
