CMSPDPM
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence based on marker.
CMSPDPM EID K M1 M2 B L PF TYPE
CMSPDPM 3 34.5 223 324 0.0 1.0   TRANS
EID Unique element identification number.
(Integer > 0)
K Stiffness value.
Default = 0.0 (Real or blank)
M1, M2 Marker identification number.
(Integer > 0)
B Damping value.
L Unstretched length of spring damper.
Default = 0 (Real ≥ 0.0 or blank)
PF Preload force.
Default = 0 (Real or blank)
TYPE Type.
TRANS
ROT
blank
Default: TRANS
  1. The spring damper force is along the line segment connecting the marker M1 and M2.
  2. The positive preload force is a stretching force.
  3. This card is represented as a spring element in HyperMesh.
