OS-E: 5000 Conjugate Heat Transfer Analysis (TFSI) of Inline-4 Engine Head with OptiStruct and AcuSolve
The Conjugate Heat Transfer Analysis of a cylinder head to evaluate temperatures in the engine block by taking into account the coupling effect with the fluid domain.
Figure 1. FE Model
Model Files
The model file used in this example includes:
TFSI_PWT.zip
Model Description
- FE Model
- Element Types
- CHEXA
- MAT1
- Young’s Modulus
- 21500 MPA
- Poisson Ratio
- 0.3
Results
Figure 2. Temperature Contour
Figure 3. Pressure Contour on the Fluid Domain
