COUPLER
Bulk Data Entry Defines a coupler connecting two or three joints.
COUPLER COID JID1 TYPE1 RATIO1 JID2 TYPE2 RATIO2
  JID3 TYPE3 RATIO3
COUPLER 3 1 T 2.0 4 R 1.0
COID Unique coupler identification number.
(Integer > 0)
JIDi Joint identification numbers.
No default (Integer > 0)
TYPEi Type. 3
TRA
Translational motion
ROT
Rotational motion
No default
RATIOi Coefficients of the coupler constraint equation.
Default = 1.0 (Real)
  1. COUPLERs are only valid in a multibody solution sequence.
  2. At least JID1 and JID2 need to be defined.
  3. The type is optional, if the Joint is revolute or translation; but if the joint is cylindrical, the type should be set to TRA to denote that the translational motion is coupled or ROT to specify that the rotational motion is coupled.
